Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
Thread: VR6 misfire (dizzy model) only in first / second gear under light acceleration
  1. #31
    Regular vr6monkey's Avatar
    Join Date
    23rd May 2007
    Location
    Andover, Hampshire
    Posts
    107
    Appears to be, I've had the car since July and no problems so far.
    Good luck sorting your problem.
    Addicted to all things Corrado.
    92 (K) VR6 - Flash Red - Work In Progress...
  2. #32
    Newbie
    Join Date
    22nd October 2003
    Location
    Belfast
    Posts
    83
    Ah super i'll give that a go!
    2003 996 Turbo
    1995 Mystic Blue VR6
    Previous: Renault 21 Turbo, M3.
  3. #33
    A couple things I would check if you haven't, is the throttle body and throttle cable. If you get baked on oil on the throttle plate edges, it can hang up the plate. Usually it has the effect of idling higher than normal as it won't close all the way being bunged up with carbon. Make sure the throttle cable isn't binding as well when this occurs and everything mechanically looks good.
    The other is the vacuum lines. They can look fine, but can get very hard, and then no longer seal when warmed up since they are no longer as flexible as they were. It won't affect idle, but then when taking off, at higher vacuum, can mess up things. Sounds like a frustrating problem. I hate drivability problems.
Similar Threads
  1. vr6 dizzy model. ignition coil for sale - SOLD
    By VAG-hag in forum Parts for Sale
    Last Post: 11th November 2014, 4:52 AM
  2. Changing gear under hard acceleration
    By Joss_Durnan in forum Drivetrain
    Last Post: 20th June 2011, 8:59 AM
  3. Replies: 12
    Last Post: 14th March 2008, 4:55 PM
  4. Replies: 9
    Last Post: 17th July 2007, 2:36 PM
  5. Misfire/hesitant acceleration etc etc!
    By CazzaVR in forum Engine Bay
    Last Post: 4th August 2003, 8:44 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
