Results 1 to 4 of 4
Thread: Corrado under body fuel pump assembly
  1. #1
    I think that my under body fuel pump has died, its been noisy for quite a while and now it does not buzz when turning the key
  2. #2
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,962
    Worth checking/replacing the fuel pump relay before forking out for a new pump.
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  3. #3
    Quote Originally Posted by seanl82 View Post
    Cheers dude, Is the fuel pump relay the same kne for kth under body and in tank fuel pumps
  4. #4
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,962
    I think so. Though I only have experience of VR6 which doesn't have an underbody one, but the in tank one is relay number 67 or 167. If you remove the fuse cover, the relays are above the fuse board. You should be able to tell if it's working by simply putting your finger on it then turning the ignition on. You should feel it click where it engages.
    Ah, just saw the other thread. As mentioned if one is priming then the relay sounds good.
    CCGB #3982
Similar Threads
  1. Replies: 0
    Last Post: 26th June 2014, 4:59 PM
  2. Fuel pump assembly parts?
    By VW Jay in forum Engine Bay
    Last Post: 17th June 2014, 9:22 AM
  3. Under car inline fuel pump assembly?
    By Mike16v in forum Wanted
    Last Post: 17th February 2014, 3:25 PM
  4. 16v under car fuel pump assembly
    By peteg40 in forum Wanted
    Last Post: 13th December 2013, 9:48 PM
  5. Lift Pump/Fuel Pump Assembly help -
    By Moreado in forum Engine Bay
    Last Post: 25th May 2013, 1:44 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
