Results 1 to 7 of 7
Thread: Rear trailing arm bushes, help please.
  1. #1
    Newbie
    Join Date
    2nd May 2015
    Location
    Mansfield
    Posts
    50
    Hello everyone,
    I'm restoring an old rear VR axle and I'm hoping to change the rear trailing arm bushes for a set of powerflex ones I've bought.
    I was hoping if anyone had the vw special tool 3111 I could borrow it or maybe someone send me the specs for one so I can have one made??
    Many thanks
  2. #2
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    Plymouth
    Posts
    5,686
    I don't think you need the tool for poly bushes mate. Stock ones on the other hand - what a nightmare!
    95 Classic Green VR - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|BBS RX228s|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  3. #3
    Enthusiast
    Join Date
    2nd October 2005
    Location
    cumbria
    Posts
    393
    You should be able to drill the rubber part of the old ones out then carefully cut the remaining sleeve with a hacksaw blade, poly ones just tap in with a bit of the supplied lube on them but some folk don't recommend them as they don't have any give in them like the original type
  4. #4
    Newbie
    Join Date
    2nd May 2015
    Location
    Mansfield
    Posts
    50
    Righto ok, I'll try the cut and saw method, fingers crossed it'll come apart without too much of a fight.
    As for the give, I'm not too worried, I've got a KW v3 set of coilovers fitted so with these fitted too I'm hoping she'll corner like an F1 car, possible future track toy
  5. #5
    It does radically alter the handling losing the passive rear wheel steering. It will make it more predictable and stiffer but ultimately less agile.
    A Corrado is for life, not just for the MOT.
    [ WARNING: the above message may contain irony, sarcasm and outright lies. ]
    ** Every time you think about sex, another Corrado gets written off. **
  6. #6
    Newbie
    Join Date
    2nd May 2015
    Location
    Mansfield
    Posts
    50
    Oh that sucks, well I'm fortunate that I have a spare axle, so if the stiffness ruins the ride I'll swap it over again.
    Thanks for the help all
  7. #7
    ⋆⋆ CF Member ⋆⋆ Jim Bowen's Avatar
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,693
    When i fitted the powerflex rear bushes, they had 3 slots in the bush where it passes through the axle, this lets water in and it rotted out the mounting points on my axle. I notice the newer powerflex bushes don't have these slots.
    Just like a golf................But better!!!
Similar Threads
  1. Bent trailing arm?
    By Critical_Mass in forum Drivetrain
    Last Post: 3rd May 2012, 10:52 AM
  2. Help with rear bushes and rear brakes
    By TanVr6 in forum Drivetrain
    Last Post: 3rd November 2011, 11:47 PM
  3. Rear beam bushes and rear arb
    By harryc in forum Drivetrain
    Last Post: 13th April 2011, 8:13 PM
  4. Trailing arm
    By Dr Forinor in forum Drivetrain
    Last Post: 13th April 2006, 12:54 PM
  5. Rear subframe/trailing arm assy
    By stevemac in forum Archive
    Last Post: 3rd September 2003, 8:36 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
